Please offer your opinion 1
FTank
29
If you are in possession of a draft copy of API 650 Proof 1 January 2007 - refer to:
3.1.5.2 under Vertical Shell Joints par b. - "shell courses shall be flush-stacked on the inside"
3.1.5.3 under Horizontal Shell Joints par b. - "abutting shell plates at horizontal joints shall have a common vertical centerline"
Question - do you find these paragraphs contradictory?
If 3.1.5.2 is talking about alignment at a vertical joint where one plate is thicker, and if 3.1.5.3 is talking about alignment of one course above the other, I don't see a contradiction. It might help to reword things to make it more clear, though.
JStephen:
Thanks for your response.
Do you design tanks with shells of different thicknesses within the same course?
FTank
You might want to look at Proof #2 then re-ask your question. Maybe something has changed.
Joe Tank
I think I mis-read the original statement, which says "courses" will be aligned- I was thinking "Plates will be aligned". And yes, that would be a contradition between the two sections.
Application where plates in a course vary would be flush manway insert plates under older version of the standard.
Thanks to all who replied. I have reviewed the 2nd draft as doct9960 suggested and the reference to flush-stacking has been removed.
