I have a application that requires a PLC to controll the thermostats of two large a/c units in the following manner by overriding the t-sats via PLC. 1. Only one unit can start and run at the same time. 2. it can run for 14 min and then ask if the other unit needs to come on, if not it can remain running and then ask again in 14 minutes, or shut off when the desired temp is reached via t-sat. 3. The plc needs to be installed between both t-sats to controll the on off of each unit. 4. They can not ever start or run at the same time ...power is not avaiable to allow both to run or star together without tripping the breaker and the transformer is a 75KVA and that is only sised for one unit at a time. Please help with suggestions,wirring and programming suggestions
Ron
325-668-1015
Ron
325-668-1015
