Plate/shell model
warrenw
54
Does anyone know if it is possible to develope a plate/shell 3D model with Inventor 7 that does not have a thickness?
It's like drawing a circle and then extruding just the circle as a hollow pipe with no wall thickness.
I am trying to create a 3D model that will represent a vessel with a nozzle that will be inputed into an older(1999) Algor FEA program as thin walled plate/shell elements. The thickness is inputed during the decoding stage based on the vessel's wall color.
I'm having trouble inputing a solid wall model with different surface colores into the Algor program.
It keeps coming up as all one color.
I need different surface colors to idenify what surfaces will be loaded with pressure.
So,can a plate/shell model be created with Inventor 7 ?
Have you tried extruding as a surface instead of a solid? In IV 8 select surface vs solid for output type in the dialog box. I thought IV 7 had the same option.
jlcochran1;
Thanks for the reply.
I tried what you said and it will create a picture of what I'm looking for, unfortunatly Inventer will not let me save it as an IEGS file (which is what the Algor program is looking for).
I also tried sweeping the circle along a line and came up with the same results.
Interesting. When attempting a "save copy as" in Inventor 8 to iges format it appears to save correctly, with iges options. However the file created has an .xlo extension and cannot be reopened by Inventor. FYI, I was able to create a similar surface in SolidWorks 2003 and save as iges and then open in Inventor.
Try making your part then remove face(s) that you do not want.
There should be 2 files. XLO and IGES files. Use the IGES. Alos ALGOR should be able to read in a STEP or SAT file. These can be exported from Inventor as well.
None of these formats will retain color information.
Sean Dotson, PE
Autodesk Inventor Certified Expert
Autodesk Inventor Tutorials & More
