Plate manufacturing process 1
MFQC
Materials
Jan 3, 2015
18
Hi
Do you know what are the differences in production of EN structural materials such as S355 and ASME SA516 grade 70?
If they are both produced in one manufacturer , what additional requirements are met for producing SA 516?
According to ASME SecVIII Div1 UCS-23 we are not allowed to use S355. If We test S355 with the requirements of SA 516, are we allowed to use this structural material in pressure parts of our vessels?
Is there any interpretation in ASME Code for this issuE?
FZQC, you would have to compare the two specs side-by-side I'd think, I am not at all familiar with EN specs.
Recertification can be done, see UG-10. Note that I have no experience with such.
Mike
FZQC...
We often receive Aerospace raw-stock alloys/forms that are mill-marked with MULTIPLE specifications that it is cross/co-qualified to-meet/exceed. Many times it includes 'oldest-to-newest' aerospace/mil specifications [MIL-x-xxxx, QQ-, AMS-QQ-, AMSxxxx]… PLUS 'commercial standards'... such as ASTM or ASME.
In general most metallic material made 'today' is produced to meet/exceed the most rigorous specification requirements... so by definition it meets/exceeds any 'lower performance specification' standard... hence can be used when any of the 'lower-performance' specifications are called-out/mandated. This makes sense in the evolutionary world of materials... good-stuff 40-years ago is mediocre today, so there is usually lowering demand for the lower performance metals. Soooo... why 'deliberately' make material to ONLY meet an inferior spec/standard that is diminishing in quantity-demand? Example: high quality vacuum arc re-melt alloy steel made today is superior to aircraft-grade air-melt steel 40-years ago. Conclusion: OEMs Make the higher performance/quality material and call it 'good' across the specification spectrum... with a single cert/qual-test regimen... and reduced raw material costs... which is a 'no-brainer' extrapolation!
Regards, Wil Taylor
o Trust - But Verify!
but, there may be testing requirements or trace element requirements, or some other detail that is only included in the processing and reporting when it is specified.
The material may be the same, but the documentation will not tell you that.
And in many cases the specification has rules on the thermomechanical history of the material, so to re-certify may involve heat treatment and testing.
Usually, higher C % are found in USA materials when compared to EN steels.
Additionally, for pressure vessels you do not want S355 but P355 (S: structural steel, P: pressure steel).
An important difference is the manner of testing (location/direction of specimen, ...).
The production and testing of S355 plates is quite different to SA516 Grade 70. Some main differences:
1) SA 516 requires a fine grain steel. Most of the S355 grades are not necessarily fine grain treated, e.g. the most common S355J2.
2) The limitations for the chemical composition between SA 516 and S355 are quite different. E.g. SA 516 limits the Nb(Cb)-content to 0.02%. Or most S355 grades are Nb-alloyed to meet the carbon-equivalent limitations of EN 10025.
3) SA 516 requires a reduction ratio (slab thickness to plate thickness) of 3.0:1 for strand cast (or other metallurgical and testing measures). This is not required for S355. In material certificates, the reduction ratio is usually not indicated, so not available to the client.
4) SA516 requires other dimensional tolerances, e.g. an under tolerance in thickness of max. 0.3 mm. S355 is generally delivered with dimensional tolerances according EN 10029 class A, which allows under thicknesses between 0.3 and 1.3 mm depending on the nominal plate thickness.
5) For surface condition of S355 grades EN 10163 applies. This standard is less severe than SA 20. E.g. Surface imperfections need not to be grinded up to a depth depending on nominal thickness (0.2 to 1.5 mm). Grinded areas may have a thickness under the minimum thickness (0.3 up to 2.2 mm depending on nominal thickness), not allowed for SA 516.
6) SA 516 requires a furnace normalising for thicknesses over 1.5 inch, or for all thicknesses if impact tested. S355 is produced either as-rolled (e.g. S355J2+AR), thermomechanical rolled (S355M) or normalised (S355J2+N, S355N). Normalising can be done either by normalising rolling or furnace normalizing. If normalised, only the letter N is indicated in the certificate. Usually the client is not able to identify if furnace normalised or normalising rolled. Normalising rolling is considered by ASME not to be equivalent to furnace normalising, in contrary to EN.
7) For normalised plates, ASME requires the indication of temperature and holding time in the certificate. This is not required by EN 10025 and usually not done.
8) SA 516 requires testing per plate-as-rolled, S355 requires testing per lot (heat and 60 t). Depending on plate thickness a plate-as-rolled often weights less than 10 t.
9) The form of test specimen is different in both Standards. E.g. flat tensile specimen need to have full thickness in ASME whereas EN allows a machining down to a thickness of 30 mm.
10) S355 requires the determination of the upper yield point (ReH), SA 516 requires the determination of yield strength either by the 0.2% offset or by the 0.5% extension under load method.
11) S355 requires the determination of the proportional elongation A5, SA516 requires the determination of non-proportional elongation A2" or A8"-
12) If impact tests are required, the hammer radii are different (2mm vs 8 mm).
Another 10 differences can easily be found.
Sure, it is possible to produce a multiple grade SA516-70/S355J2+N. In this case, the manufacture has to produce to the most stringent requirements of both standards. The production and testing costs are always higher than the costs of the most expensive of the different grades (SA 516-70). Nevertheless multiple grades can be profitable for a stockholder as he may save to stock the individual grades.
Dear ulyssess
Thanks alot for your valuable post.
