engpes
- Feb 10, 2010
- 175
I am applying a load to the center of a plate that is stiffended by beam elements (see attached sketch). Assuming the beams are rigid, how can I calculate the deflection if the load is applied at the center of the plate.
The plate is seal welded to the rigid beams. Thanks.
