Plastic/Black Steel Supply Grilles Manufacturers
supaman79
Does anyone know of any Plastic or Black Steel R,G,D Manufacturers?
I believe that
Carries lines that could be made of plastic or black steel... what is the application?
**If you are not part of the solution, then you are part of the precipitate.**
Metalaire does some plastic supply diffusers that I have used, and probably does other things as well. Air Concepts ( makes some plastic ball-and-socket diffusers that are great for spot cooling applications.
---KenRad
