Plane/Origin Selection Macro 2
handleman
Automotive
One thing that's always been a little inconvenient to me is selecting the original 3 planes or origin of a component in an assembly for mating or other purposes. You have to click the component, find it in the design tree, expand it out, and pick the desired plane. I finally got tired enough of doing that to write this macro. It works best when assigned to a keyboard shortcut (I have mine mapped to "R"). To use it, select any component in an assembly. It may be a part, subassembly, or a part of a subassembly (any depth). Then run the macro. It will select the origin of the component. When run multiple times without the user changing selections it will cycle through selecting the origin and the 3 primary planes in succession. You can actually make multiple selections and the macro will only operate on the last selected component without losing your other selections.
The only thing that stinks is that macros are disabled while the "mate" property manager is displayed. :-(
This macro is loosely based on an example in the API help for selecting the origin of an assembly component. However, when you mate the origin of a component in an assembly it is actually mating "Point1@Origin@....". Figuring out how to select that Point1 correctly at any depth of subassembly gave me fits, but I think it's right.
Hope it's useful to you!
Code:
' Macro to select main reference geometry of an assembly component
' for easy mating.  Modified extensively from the
' "Select Origin of Assembly Component Example (VB)" in
' SolidWorks and Add-Ins API Help
' Preconditions:
'       (1) Assembly document is open.
'       (2) One or more items is selected.
' Postconditions: One of the 3 original planes or the
' origin of the last selected component is selected.
Option Explicit
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swSelMgr                    As SldWorks.SelectionMgr
    Dim swSelComp                   As SldWorks.Component2
    Dim swCompModel                 As SldWorks.ModelDoc2
    Dim swFeat                      As SldWorks.Feature
    Dim bRet                        As Boolean
    Dim GeneralSelObj               As Object
    Dim myFeatureCollection         As New Collection
    Dim i                           As Integer
    Dim CurSelCount                 As Long
    Dim MyTempPointObj              As Object
    Dim mySelStr                    As String
    Dim NewObjToSelect              As Object
    Dim Chunks                      As Variant
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    If swModel.GetType <> swDocASSEMBLY Then
        MsgBox "This macro works on assembly documents only."
        Exit Sub
    End If
    Set swSelMgr = swModel.SelectionManager
    CurSelCount = swSelMgr.GetSelectedObjectCount
    If CurSelCount = 0 Then
        MsgBox "Nothing was selected"
        Exit Sub
    End If
    Set GeneralSelObj = swSelMgr.GetSelectedObject(CurSelCount)
    Set swSelComp = swSelMgr.GetSelectedObjectsComponent(CurSelCount)
'    Set swCompModel = swSelComp.GetModelDoc
    swSelMgr.DeSelect CurSelCount
    Set swFeat = swSelComp.FirstFeature
    Do While Not swFeat Is Nothing
        If "RefPlane" = swFeat.GetTypeName Then
             myFeatureCollection.Add swFeat
        End If
        If "OriginProfileFeature" = swFeat.GetTypeName Then
            Chunks = Split(swSelComp.Name2, "/")
            mySelStr = "Point1@Origin@" & Chunks(0) & "@" & _
                Left(swModel.GetTitle, Len(swModel.GetTitle) - 7)
            For i = 0 To (UBound(Chunks) - 1)
                mySelStr = mySelStr & "/" & Chunks(i + 1) & "@" & Left(Chunks(i), (InStrRev(Chunks(i), "-") - 1))
            Next
            swModel.Extension.SelectByID2 mySelStr, "EXTSKETCHPOINT", _
                0, 0, 0, True, 0, Nothing, swSelectOptionDefault
            myFeatureCollection.Add swSelMgr.GetSelectedObject(swSelMgr.GetSelectedObjectCount)
            Exit Do
        End If
        Set swFeat = swFeat.GetNextFeature
    Loop
    Set NewObjToSelect = Nothing
    'MsgBox myFeatureCollection.Count
    If myFeatureCollection.Count > 4 Then
        MsgBox "Error: more than three planes before origin in design tree!"
        Exit Sub
    End If
    For i = 1 To myFeatureCollection.Count
        If GeneralSelObj Is myFeatureCollection.Item(i) Then
            Set NewObjToSelect = myFeatureCollection.Item((i Mod myFeatureCollection.Count) + 1)
            'Use of Mod above cycles back to first item if last item matches.
        End If
    Next
    If NewObjToSelect Is Nothing Then
        Set NewObjToSelect = myFeatureCollection.Item(myFeatureCollection.Count)
    End If
    bRet = NewObjToSelect.Select(True): Debug.Assert bRet
End Sub
Handleman,
Cool. Thanks. Works great sep for a bug I've found: I'm running into a debug error when a lightweight component is selected prior to running the macro. I am running 2005, so I'm not sure this would be an issue in near S/W.
Also, would you mind if I included this macro on my site?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
Sorry, I forgot to mention about lightweight components. I think 2006 added a lot of functionality for lightweight components. You can add mates to lightweight components in 2006, and their three primary planes are available in the design tree.
Try this version. It will check the version of SolidWorks that is currently running. If the version is earlier than 2006 it will then check the suppression state. If the component is not resolved it will either resolve it or exit the macro based on user choice. I don't have 2005 to check this on, but it resolves components correctly when I change the minimum release to 2007 rather than 2006.
Feel free to put it up on your site - just make sure the header plugs Eng-Tips!
Code:
' Preconditions:
Option Explicit
Sub main()
    Dim bRet                        As Boolean
    Dim i                           As Integer
    Dim swVer                     As Variant
    Dim ResolveIt                   As Integer
        Exit Sub
    End If
        Exit Sub
    End If
    swVer = Split(swApp.RevisionNumber, ".")
    If CInt(swVer(0)) < 14 Then
        If swSelComp.GetSuppression <> swComponentFullyResolved Then
            If swSelComp.GetSuppression <> swComponentResolved Then
                ResolveIt = MsgBox("The component selected is not fully resolved." _
                   & vbCrLf & "This functionality is only available for lightweight" & vbCrLf & _
                   "components in SolidWorks 2006 or greater." & vbCrLf & vbCrLf & _
                   "Resolve this component now?", vbYesNo, "Upgrade Time!")
                If vbYes = ResolveIt Then
                    swSelComp.SetSuppression2 swComponentFullyResolved
                Else
                    Exit Sub
                End If
            End If
        End If
    End If
        End If
            Next
            Exit Do
        End If
    Loop
        Exit Sub
    End If
        End If
    Next
    End If
End Sub
handleman,
This is a great time saving macro, I know I'll use it a lot - THANKS. My only question is can it be used to cycle through any other planes that are created and appear later in the feature manager tree. An example would be, often on a pipe fitting I'll add an "Installation Plane" at the approximate location on the threaded end for thread engagement into the next part.
thanks,
RacingD98
NICE!! That's worth a star IMO. I will use this quite often.
Craig Sink
Mechanical Engineer
Force Design, Inc.
Sure! Here's a new version that will cycle all reference planes and the origin. To activate this functionality, change the value of the constant STOPATORIGIN from True to False.
I added another constant (FIRSTREF) that you can change to start the cycling with one of the 3 primary planes rather than the origin.
I also caught (and fixed, of course) a bug that occurred when the macro was run before the assembly was saved.
I've ended up using this macro even more than I thought I would. Because I do one-off automation equipment design I use a lot of simple mates. I wrote three more macros to go along with this one since macros don't work with the Mate command active. I can post those if anyone's interested. They will add a Coincident, Parallel, or Concentric mate to pre-selected entities with a single button press without activating the Mate command and property manager. They actually run faster than the Mate command because they rely on your judgement to pre-select entities that are suitable for each mate rather than checking your selection set for all possible mate types.
Anyway, here's the new reference geometry selection macro:
Code:
' Preconditions:
' Postconditions: One of the reference planes or the
Const STOPATORIGIN As Boolean = True
Const FIRSTREF As Long = 4
'Change the value of FIRSTREF above if you want
'one of the primary planes to be the first feature
'selected by the macro.  Values are:
    'Front  = 1
    'Top    = 2
    'Right  = 3
    'Origin = 4
Option Explicit
Sub main()
    Dim bRet                        As Boolean
    Dim i                           As Integer
    Dim DocTitle                    As String
        Exit Sub
    End If
        Exit Sub
    End If
                Else
                    Exit Sub
                End If
            End If
        End If
    End If
        End If
            If StrComp(Right(swModel.GetTitle, 7), ".sldasm", vbTextCompare) <> 0 Then
                DocTitle = swModel.GetTitle
            Else
                DocTitle = Left(swModel.GetTitle, Len(swModel.GetTitle) - 7)
            End If
            mySelStr = "Point1@Origin@" & Chunks(0) & "@" & DocTitle
            Next
            If STOPATORIGIN Then
                Exit Do
            End If
        End If
    Loop
        End If
    Next
        Set NewObjToSelect = myFeatureCollection.Item(FIRSTREF)
    End If
End Sub
I'd certainly be interested! If I had API experience, I'd have done this loong ago!
Craig Sink
Mechanical Engineer
Force Design, Inc.
handleman,
Your new version is even better than the first, thanks again. I too would be interested in the macros, anything to do my job faster.
RacingD98
Here you go, Craig. These are pretty basic and straightforward. The code is almost identical for each one, so be careful with the copy/pasting. :-) Just pick your two entities for mating and run one of these macros. When there is a possibility of flipping alignment the macro will ask you with a message box whether you want to keep the current alignment or flip it. I figured the current would be most common, so I made the default be "Yes", which you can select by hitting the spacebar, Return key, or clicking "yes" with the mouse.
Enjoy!
Coincident mate:
Code:
Dim swDoc As SldWorks.ModelDoc2
Dim swAssy As SldWorks.AssemblyDoc
Dim swMate As SldWorks.Mate2
Dim ErrorLong As Long
Dim MsgReply As Integer
Dim NewAlign As Long
Sub main()
Set swDoc = swApp.ActiveDoc
Set swAssy = swDoc
Set swSelMgr = swDoc.SelectionManager
If swDoc.GetType <> swDocASSEMBLY Then
    MsgBox "Use this macro in Assembly documents only.", vbCritical
    Exit Sub
End If
If swSelMgr.GetSelectedObjectCount <> 2 Then
    MsgBox swSelMgr.GetSelectedObjectCount & " items selected.  Req'd number is 2.", vbCritical
    Exit Sub
End If
Set swMate = swAssy.AddMate3(swMateCOINCIDENT, swMateAlignCLOSEST, False, 0, 0, 0, 0, 0, 0, 0, 0, False, ErrorLong)
If Nothing Is swMate Then
    MsgBox "Mating Error #" & ErrorLong & " Mate not added.", vbCritical
    Exit Sub
End If
If swAddMateError_OverDefinedAssembly = ErrorLong Then
    MsgReply = MsgBox("Overdefining mate.  Keep anyway?", vbYesNo + vbQuestion)
    If vbNo = MsgReply Then
        swDoc.ClearSelection2 True
        swMate.Select True
        swDoc.Extension.DeleteSelection2 0
    Else
        'swDoc.EditRebuild3
    End If
ElseIf swMate.Alignment <> swMateAlignCLOSEST Then
    MsgReply = MsgBox("Keep current alignment?", vbYesNo, "Mate Alignment")
        If swMate.Alignment = swMateAlignALIGNED Then
            NewAlign = swMateAlignANTI_ALIGNED
        Else
            NewAlign = swMateAlignALIGNED
        End If
        swMate.Select True
        swAssy.EditMate2 swMateCOINCIDENT, NewAlign, False, 0, 0, 0, 0, 0, 0, 0, 0, ErrorLong
            MsgReply = MsgBox("Flip caused errors.  Undo?", vbYesNo + vbQuestion)
            If vbYes = MsgReply Then
                swDoc.EditUndo2 1
            End If
        End If
        'swDoc.EditRebuild3
    End If
ElseIf swAddMateError_NoError <> ErrorLong Then
    MsgBox "Mate error #" & ErrorLong & vbCrLf & "Mate not added"
    If Not swMate Is Nothing Then
        swMate.Select True
    End If
ElseIf swMate.GetErrorCode <> swFeatureErrorNone Then
    Select Case swMate.GetErrorCode
        Case swFeatureErrorMateInvalidEdge
            MsgBox "Invalid edge"
        Case swFeatureErrorMateInvalidFace
            MsgBox "Invalid Face"
        Case swFeatureErrorMateFailedCreatingSurface
            MsgBox "Mate surface type not supported"
        Case swFeatureErrorMateInvalidEntity
            MsgBox "Supressed, Invalid, or Missing Entity"
        Case swFeatureErrorMateDanglingGeometry
            MsgBox "Mate geometry is dangling"
        Case swFeatureErrorMateEntityNotLinear
            MsgBox "Non-linear edges cannot be used for mating"
        Case swFeatureErrorMateOverdefined
            MsgBox "Mate is overdefining"
        Case swFeatureErrorMateIlldefined
            MsgBox "Mate cannot be solved (Ill-Defined)"
        Case swFeatureErrorMateBroken
            MsgBox "One or more entities suppressed or invalid for this mate"
    End Select
    swMate.Select True
End If
End Sub
Concentric mate:
Code:
Sub main()
Set swAssy = swDoc
    Exit Sub
End If
    Exit Sub
End If
Set swMate = swAssy.AddMate3(swMateCONCENTRIC, swMateAlignCLOSEST, False, 0, 0, 0, 0, 0, 0, 0, 0, False, ErrorLong)
    Exit Sub
End If
        swMate.Select True
    Else
        'swDoc.EditRebuild3
    End If
        Else
        End If
        swMate.Select True
        swAssy.EditMate2 swMateCONCENTRIC, NewAlign, False, 0, 0, 0, 0, 0, 0, 0, 0, ErrorLong
                swDoc.EditUndo2 1
            End If
        End If
        'swDoc.EditRebuild3
    End If
        swMate.Select True
    End If
    End Select
    swMate.Select True
End If
End Sub
Parallel mate:
Code:
Sub main()
Set swAssy = swDoc
    Exit Sub
End If
    Exit Sub
End If
Set swMate = swAssy.AddMate3(swMatePARALLEL, swMateAlignCLOSEST, False, 0, 0, 0, 0, 0, 0, 0, 0, False, ErrorLong)
    Exit Sub
End If
        swMate.Select True
    Else
        'swDoc.EditRebuild3
    End If
        Else
        End If
        swMate.Select True
        swAssy.EditMate2 swMatePARALLEL, NewAlign, False, 0, 0, 0, 0, 0, 0, 0, 0, ErrorLong
                swDoc.EditUndo2 1
            End If
        End If
        'swDoc.EditRebuild3
    End If
        swMate.Select True
    End If
    End Select
    swMate.Select True
End If
End Sub
I forgot to mention - one of the things that makes these macros faster is that they don't incorporate an EditRebuild. For that reason the mates they add don't immediately show up in the individual components' "Mates" folder. They still show up in the assembly's list of all mates, and they're still fully solved, they just don't show in the individual components' list until the next rebuild.
