Soldierson
I am involved in a renovation of a 1-story 1950's era warehouse built with plain load bearing masonry walls (no steel) supporting a simple bar joist roof system. The masonry is a closed cell hollow block. i.e. you can't grout it. Any references on how to reinforce the masonry for wind loads without disturbing the original building look and architecture? I am proposing to remove the existing brick veneer and apply a reinforced cement stucco. Are there any other ways? Also in analysis of the existing structure, I am using an allowable compressive strength of 100 psi (gross area) and allowable shear stress of 22 psi based on BIA tech references. Sound reasonable?
