We have been working on a piston type air intensifier. 100 psi air in, 400 psi air out operating dry. The heat of compression has limited the elastomer sealing material choices to fluorocarbon based materials, and none seem to work well. The barrel of the compression cylinder has been hard chrome plated to reduce wear and the piston travels about 10” per stroke at about 380 ft/min.
When looking at plain bearing design materials are listed with a PV value. P being projected area pressure, and V being the velocity, or speed of movement. The published values are for lubricated bearings.
When sealing a surface air tight, the piston ring and barrel that the ring runs in must be have a zone that is dry with no leakage.
Is there any reliable published data for dry PV values of materials?
What are some recommended materials for this application?
What would be the lest expensive, and fastest way to determine the dry PV of several different material combinations?
