Placing Datum Point in Sketch Mode
  • Thread starter Thread starter bhayden
  • Start date Start date
B
bhayden
Guest
I have a sketch with a horizontal and vertical centerline. How do I place a Datum Point at the intersection of the two?
Bernie Hayden
XKL LLC
you cannot add a datum point with this way
you must choose the datum point creation icon > sketch and then you can create as many datum points you want
proe cannot create datum points n addition with other sketch entities
xcad
>proe cannot create datum points n addition with other >sketch entities
Damn, I was afraid that was going to be the answer. Here's what I'm trying to do. Maybe someone has an answer on what the correct way to accomplish this is.
I sketcher I have the horizontal and vertical centerlines. These define the center of a surface mount connector body. The dimensions to the centerlines show OK on the drawing but it would be nice if they referenced a point or mark at the center extending off to some far off point. Functionally it would be nice to have a feature (axis or datum point) to locate the connector in the PCB assembly. I guess placing the datum before sketching the pad outlines is the way to go.
-Bernie-
You can place an axis point in your sketch which will show up as an axis that you can reference. Maybe this will work?
Thanks, axis point is perfect!
-Bernie-
