So I have a set of gears
teeth:76
MOD: 3
Pressure Angle: 20 deg
pitch dia: 9.444
tooth angle: 18.1* (LH/RH)
gear lash: .003-.003
pin dia: .204
Over pins: 9.7269/9.7244
these are in a very old machine and the center distance is measuring: 9.460
we have a lot of other machines out there where the center distance is 9.444 so i cant change the angle to make the pitch dia work.
an engineer I work with wants to just change the pitch dia to 9.460" and the OD. to 9.696" and says we can leave the MOD and Angle the same. that you have to match the pitch dia to the center distance. I know ideally that is what you want to do. But from my understanding you can just arbitrarily change a pitch dia to match your center distance while leaving everything else the same.
I figured we should do a tooth correction. using a couple gear calculators this is the info I come up with.
teeth:76
MOD: 3
pitch dia: 9.444
pin dia: .204
correction factor: .0694
center distance: 9.460"
teeth:76
MOD: 3
pitch dia: 9.444
pin dia: .204
teeth:76
MOD: 3
pitch dia: 9.444
pin dia: .204
