LateApexEE
I'm going to leave this a little vague, so bear with me.
A naturally aspirated, 13:1 big cam BMW race motor was brought to me for mapping of its Motec M4. The engine was built by a reputable builder. The car was started and the timing set using the CRIP page and verified using a timing light as normal, base fuel pressure, etc (all normal first startup checks). I mapped the car as I usually would on our Dyno Dynamics dyno using 109 octane VP fuel. I finished the fuel map and was working on the timing map, steady state in the lower load regions then doing sweep runs at higher RPM and loads to keep coolant temps in check. I was using the torque feedback from the dyno to determine MBT while doing the sweep runs. The timing was 18* starting the pull at 3k RPMs ramping up to 22* by redline, all in by 6500 or so RPMs. The engine made great power (~240 HP on these early pulls), had no blowby, and was otherwise well behaved. The WOT mixture was .86 lambda. The spark plugs were all an even, normal light brown color and they were removed and inspected several times during the day. After 4-5 power runs the engine developed a noise at idle. It was shut down, removed, and inspected.
What was discovered was a scuffed piston skirt on one cylinder. The top of the piston looks perfect, bearing is perfect, rings good, no damage at all on top of the piston, but the skirt is scuffed along with the cylinder wall. The engine builder claims that running the timing this low will damage the piston in this manner. The builder claims to run 10* more timing across the board, which is totally believable. So how did he get to this timing value? I assume by testing until no more power could be achieved. He further claims that high EGTs are to blame for the piston damage. If this is true, then so be it I am prepared to accept responsibility but I have never seen an engine fail in the manner and it puzzles me. I could see damage being done if the timing was retarded severely, but the engine would not have good power or response. The exhaust ports, valve guides, and manifold show no sign of heat damage. All other cylinders look perfect.
Is it possible for an engine to be damaged in this manner by running timing that may be 10* retarded from optimal? Thanks in advance for any responses.
