I start working as piping designer in a fire fighting company. I am searching a solution to avoid the time wasting of using autocad and made mtos by myself, just counting manually all the objects.
I have heard about revit mep, it seems that a bim revolution is happening and everybody talks about it. I tried to learn it, but seems that to implement all the families requires a lot of time and furthermore revit does not generate the typical isometrics (to put the dimensions on the pipes is not so easy).
Do you think that keep on using revit is worth? Do you have any advice that can help me in this implementation?
Which is your favourite software for piping system and Why? If I have to submit cad documents with high level graphic standard costumization (decided most of the time from the client), which one is better?
Do you have any book that can help me to learn this program?
I accept every advice.
