Hello all,
Currently at my site, we have some piping that is designed to 1100 psig and 650 degF.
However due to operating issues, the piping has been exposed to 900 psig (normal operating) and 670-690 degF (max).
From my basic check, thickness is sufficient for the elevated temperature, flange rating is okay (tho everything is welded on this system).
So the only thing not checked as yet is the nozzle loading and pipe support loads via stress analysis. However for a 40 degF differential, should loading be so significant ?
Is there anything else that should be typically assessed here ? From appendix V in B31.3, this seems to deal with piping within the creep range, but this system is below that threshold.
