Hello
I have a fierce problem with a pipework header off a set of 5 pumps with respect to vibrations being transmitted form the pumps...see attached picture...water pressure 6 bar 140 degC.
A few weeks ago the coupling between the motor and pump shafts was worn and needed rubbers replaced around the bolts (sorry about the vague details). The pump caused really bad vibrations in the entire pipework above the pump on the suction and discharge headers and shock the pipes the steel structure supporting them....it was literally swaying......we shut down all pumps immediately and restarted one at the time and figure out the one that was causing problems. Got the coupling fixed and no issue since..until yesterday..another pump is now causing problems...don't know the details yet but the pipework started to shake again yesterday until the pump causing it was switched off... Surely the pumps are entitled to wear and fail without causing the system to vibrate and shake.
The pumps have bellows in and out of them but I do think the pipework going from low level to high level on the discharge side about 4.5m is a little too long....so they need additional supports at high level.......also some of the shoes under the pipes sitting on supports are just sitting there and others are spot welded into place...
Any thoughts on my issues?
R
R
