oilcivil
- May 20, 2010
- 11
Out here in California petroleum, we typically use 'T' supports with cast in place concrete "pile" foundations. Some supports have lateral forces but many are only providing vertical support. Right now there is a school of thought that all of the supports should have rebar cages in the foundations. I used to be of this school of thought because of temperature shrinkage control comments in the ACI 318. However I just came across a portion of the Plain Concrete section of the ACI that states that cast in place concrete piles are not really covered in the ACI. Additionally, read an old post by GeoPaveTraffic that mentioned rebar cages aren't really necessary for supports only under compression. Regardless, for a support like this, with little (friction) to no lateral forces, I'm not really seeing the need for the rebar cages. Has anyone run into this debate in the past? Are there any codes or standards one would point to? Also if the friction is an issue, couldn't something be places between the pipe and support to limit the lateral friction?
Thanks in advance
Thanks in advance
