I must admit I had never seen that equation, but then I don't use B 31.1 very often.
B 31.4 has a simple limit of 3 degrees which is the max before it becomes a miter or mitre joint.
However 3 degrees over 20m with a 12" (300 ND) pipe is an elastic bend of just over 1000D.
3 degrees is 1/120 of a circle. Therefore circumference of the circle is 120 x 20 = 2400m. Radius of the circle is = (circ/ PI) / 2.
I am pretty sure this won't exceed any stress limits providing the curve / bend is smooth.
At 1000D or more it will simply lie in the trench bottom.
If you think you can accurately cut a 2 degree slope on a 12" pipe then I think you're in the wrong game.
