waleed.alhishmakpc.co.com
- Jul 13, 2020
- 1
We have a operative crude oil pipeline of lenght 10 KM. We need to isolate from th emain system and prserve it for a long period.What sort of presrvation we use and which one is better. We believe that it is better to prserve by gasoil, or diesel oil to keep tha status of such for along period and without any more major corrosion. Kindly Advice
Nitrogen is good but at teh same time their will be some corrosion will take place, because nitrogen only will reduce the oxygen content on the pipeline , at the same time we have to keep the pipeline under pressure of 1.5 bar and we should continuesly check the pressure along the pipeline
Kinldy we need your advice to presrve such pipeline with above conditions
