LaSalle1940
Chemical
This is really a two-part question:
FIRST: what are the general guidelines for velocities for pipe pigs for cleaning liquid lines? I would venture a guess that a pipe pig has to travel within a certain velocity range to ensure reasonable cleaning without bypassing deposits, or moving so slowly that there's not enough momentum transfer to knock depostis off walls.
SECOND: are there references in the open literature for friction factors for pipe pigs? And if anyone knows of such references, would they please provide exact citations? It seems to me that the velocity guidelines from the first part of this question (in conjunction with the line size itself) would determine the flowrate of the liquid providing the motive power for the pig--but the resistance to forward motion provided by the pipe and the stuff that you'd want to clean off would determine the pressure of that same motive fluid (well, that, plus the geometry of the pig).
Thanks very much.
Thanks very much.
