Dear All,
I would like to inquire on the pipeline roughness adjustments for existing pipeline (for example, water), as part of the hydraulic study, we acknowledge that the pipeline roughness has increased due to scaling and possible deposition of corrosion products, this would impact the calculated pressure drops, therefore:
- For the adequacy check of existing pipeline system, can we tune the roughness factor based on actual field data, would 0.6 mm roughness be reasonable for carbon steel pipeline.
- Is there any rule of thumb (other than the old piping roughness of 10 times new carbon steel of 0.0457 mm). Do pipeline get treated like piping or they are seamless and hence the roughness impact is not accurately credible.
- If you are designing a new pipeline network, and the governing case is 20 years down the road, would you account for a higher roughness in this case?
Appreciate your views on this subject.
regards,
regards,
