Good afternoon all,
I'd like your help to understand some hydraulics.
Let's consider a centrifugal pump for clear water, installed at z=0m, with a 10 km discharge pipeline, pumping into a tank at z=100m, along a linear profile.
Let say that the losses are roughly 50m, hence a TDH of 150m under normal conditions for a given flow. Let's consider the shutoff pressure at Q=0 at around 120% of TDH, that's 180m.
Without considering any transient, what would the internal pressure of the pipe if a valve is closed at 5km or 10km ?
My understanding would be, for example at pk 5km (z=50m) 180m-50m = 120m ; and at pk=10km (z=100m) 180-100=80m. In other words, the piezometric line is flat at the shutoff pressure along the pipe profile while the valve is closed, i.e. the fluid is laminated = the pump cannot provide more "lifting energy" than Pshut-off.
Therefore, looking at this parameter only (no transient), the pressure rating of the pipeline should satisfy these pressure, i.e. derating of the thickness along the profile.
The sector concerned being waterworks, often being less stringent than petroleum or equivalent industries.
Thank you very much for your help.
And thanks to this forum, mostly ending here when looking for engineering details..
