I am putting together a calcs spreadsheet for general pipeline services operations and have run across a problem.
In the case of bulk dewatering, i.e. pigging the water out of the line with nitrogen, I need to calculate the back pressures of the MEG/MeOH slugs and also the water infront of the pig train. The gas flowrate is known in scfm, however this gives an unrealistically high liquid velocity, so I have tried converting the gas flowrate to actual volumetric flowrate as opposed to at standard conditions. This still gives unrealistically large liquid velocities. I'm assuming I'm missing something fairly obvious.
Any help appreciated.
Pipeline Services Engineer in the Oil & Gas Sector
