Pipeline alignment
zdji2003
Materials
IT
Could someone tell me, please, what kind of software is used for the drafting of pipeline alignment drawings?
Any CAD program can be used.
Helps if you can paste aerial photos on the plan track.
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
Here is attached a produced Acad dwg showing pipeline alignment but I guess it's an output of a enginnering software but I don't know what it is.
Could someone, please, have a look and help
Z.
 http://files.engineering.com/getfile.aspx?folder=b95a3360-368e-4013-965e-5d38b3aa961d&file=Pipeline_Alignment.dwg
You stated it was an "Acad dwg"... it is probably an output from a software package called AutoCAD.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
File extension is .dwg which means it is almost certainly an AutoCad drawing file. See
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
Steam Engine enthusiasts
This is without a doubt an AutoCAD compatible drawing. Many CAD packages can open and work with DWG files. The DWG file is not as standard as say DOC or XLS and it is not open source, yet it is not necessarily created by AutoCAD.
AlignDB is probably the best software for pipeline alignment sheets. It runs on top of autocadmap.
