Pipe work and frames within Atex areas 2
Tonka73
Industrial
Nov 26, 2004
4
Hi all
I need some help with pipework and frames within Atex areas. These are both chemical dosing units with pumps and pipework mounted on frames/ enclosures
1) can Plastics be used within a zone 2 environment, I assume there is an issue due to static???
2)If for example the pipework was steel (in a zone 1)would it require greater earth bonding than normal
The electrics for the unit appear easy (we just use ATEX approved materials) right??
The 2 units I am on with will be type approved by others but obviously I need to get it right the first time round
Many thanks in advance
If anyone has a contact for a firm that could advise an ATEX virgin like myself it would be a great help
regards
Gareth
