rconner, nice reference and worth a star.
DeepBlue, you need the yield strength of the 5L pipe. There are a few grades, 5L-B, X42, X52, X60, X70 ?? What do you have?
Most engineers look at the design of steel pipe without evaluating all of the possible solutions.
Using AWWA guidelines for design, a 48” diameter pipeline with 0.240 wall thickness would withstand an earthload of 20 ft. of cover. To get to 27 ft of cover you would need to increase the wall thickness to 0.500” wall thickness.
C-200 Steel Water Pipe applies to 6 inches and larger.
AWWA Steel pipe wall thickness formulas
for internal pressure design only is,
t = Pw*D/2/S/F
Pw = working pressure psig
D = outside diameter inches
S = yield strength of steel API 5L Grade ?
F = design factor AWWA usually is 0.50
Where surge pressure is > 1/2 Working pressure the formula changes and P = (Working pressure + Surge Pressure)
rconner's reference has what you need for burial stresses.
BigInch
![[worm] [worm] [worm]](/data/assets/smilies/worm.gif)
-born in the trenches.
