WE NEED TO FABRICATE BOX TYPE STEEL SUPPORTS FOR STEEM LINES, FEED WATER LINES WITH THE HELP OF CARBON STEEL CHANNELS TO FORM AS CLOSED BOX SECTIONS BY WELDING THE EDGES. IS IT NESSARY TO GASCUT /GRIND THE CHANNEL EDGES TO FACLITATE FULL PENETRATION WELDING BETWEEN TWO CHANNELS. WHAT IS THE PRATICE IN INDUSRY. DESIGN DRAWINGS ARE SILENT ABOUT IT. INDIAN STANDARDS SUGGEST GRINDIG, AND WELDING WITH BACKING STRIP TO OBTAIN FULL PENETRATION FOR SIMILAR APPLICATIONS.
