I am using a pressure vessel program to check pipe support bkt clips. I have the following questions.
1. I was reading thru WRC-107 bulletin. Section 4.2.2.3 tells you how to calculate beta for rectangular attachment. It only considers radial load P, Longitudinal moment ML, Circumferential moment Mc. My question is why it does not consider longitudinal load VL, Circumferential load Vc and torsional moment Mt? Longitudinal moment VL is certainly important for pipe support bkt clips. Why is it that WRC-107 does not consider it?
2. What is the benefit of welding the bkt clip on a poison pad? I guess it distributes the load somewhat, but how big of a difference does it make? The pressure vessel program is suggesting to put a pad for the clip. I thought a gusset will be a better solution with the gusset welded perpendicular to the clip.
