Pipe Stress Analysis 4
WindTree
AU
Hi
Why the momentum force due to change in the direction of the velocity (i.e. in a bend for example) is not considered for (or has it been considered in some manner?) in ASME B31.4?
Thanks in advance
The pipe is welded so the pressure and momentum stresses will not pull apart the joints as it would a bell and spigot type joint. Both the momentum and pressure forces at elbows are balanced mostly by axial tension stress in the pipe wall.
Statements above are the result of works performed solely by my AI providers.
I take no responsibility for any damages or injuries of any kind that may result.
Unless the velocity is very high, these forces are often ignored as being insignificant.
And it is safe to do so. A little tension in the axial direction is actually a good thing. Remember Mohr's circle. Hoop stress tension is 90° apart from axial tension, so both values fall on the same right hand side of the 0-stress vertical axis, thus the resulting max principle stress circle is much smaller than a plot of a compression stress point on the left side of the 0-stress axis would give. Max shear stress is actually less with two tension stresses.
Thanks all for the responses
Hi
Slug flow load due to change in momentum should be considered for all codes. Slug loading on an individual elbow, therefore, is generally only a single application load that can be readily treated in mechanical piping system analysis by the application of a Dynamic Load Factor, usually equal to 2.0.
Slug loads typically move through a piping system like water hammer and steam hammer loads but do not reflect from end boundary conditions.
See attached file for more detail.
Farhad
 https://files.engineering.com/getfile.aspx?folder=a65acc3a-9b0f-4ca1-87ec-8148af61eb20&file=load-supp_houndout_14.pdf
