Guest
I just found this place, and hope you guys can help me.
First, excuse me for beeing a newb.
Secondly, my post seems to have gotten quite long.
I usually over explain things, so it shouldn't take too long to read. Please read?
I have a watercooling project underway, and am not sure what size pipe i should use.
In case you are interested, i am supercooling my computer, i can provide some pictures of the project thus far.
I have a 6 foot vertical acrylic pipe being powered by a pump (outlet is a showerhead).
A flow chart of the pump can be found here: (900GA model)
I believe the chart applies to 3/4" pipe, because that is its outlet size.
I have consulted many "head loss calculators" and charts, and with 3/4" pipe i would lose under 5 feet in dynamic (frictional) head loss. (this is one of the calculators With 1" pipe the loss goes down to about 1-1/2 feet.
Adding 6 feet of static head to the dynamic head results in a figure (total head) which you match up w/ the chart given by the 900GA pump flow chart (linked above).
In this case with 1" pipe, head loss is 7.5 feet, which equals 700GPH.
However, it is not actaully 7.5 feet of head, i don't think.
With 1" pipe, the additional volume (1.778 times more volume than 3/4"
, creates additional pressure.
This can equate to additional head (if you simply consider a 3/4" pipe of the additional volume, it would be much taller).
A 1" pipe 3.375 feet high should create the same pressure as a 3/4" pipe 6 feet tall, correct?
(i calculated this by volume)
Using the "head loss calculator" (2nd link) with my assumption that a 1" pipe results in 1.778 times more head pressure that a 3/4" pipe, i calculated that a 3/4" pipe would result in a higher GPH output, despite the high friction level!
Please correct me if this is not accurate in any way.
The reason i am not so sure is because I have recieved varied information on the internet, some sites saying the volume of the pipe has no effect on pressure.
Also there is a formula which states that the PSI can be found be dividing the level of head by 2.31. This does not account for the volume of the pipe, however?
Is the volume of the pipe directly proportional to the amount of head pressure that the pump must push against?
Or does 1" pipe not produce 1.778 times more pressure than 3/4" pipe?
Does it make sense that I choose 3/4" pipe?
(waterflow is CRITICAL to this application, i am avoiding additional watts (added heat) w/ a bigger pump (1200gph), so every loss counts with this smaller pump)
Thanks So Much,
-Joe Kuta
Thanks So Much,
-Joe Kuta
