Pipe head loss - Cameron Hydraulic Data inaccurate? 1
sabotage
Has anyone had any experience using Cameron Hydraulic Data for their head loss calculations? I was recently checking some head loss calculations when I discovered that the head loss I had calculated was almost double of what was previously done. Doing some backchecking we found some discrepancies between what Cameron uses for head loss and what other sources use. For example, for a 16" CHW Sch. 40 steel pipe at 6,000 GPM, Cameron has a head loss of 9.31'/100'. ASHRAE has the head loss at around 2'/100'. I checked other sources (Bell & Gossett/Carrier/etc) and they all agree with ASHRAE's estimate.
Can anyone explain such a large discrepancy, or has any experience with large differences between Cameron and other sources?
Intersting handle...sabotage....where are you located ?
Have you tried the Crane 410 method ?
This is the methodology in most common usage....as i understand
I'm located in Central Jersey.
I have tried the Crane 410 method, and it gives similar results to ASHRAE. My question is why is Cameron giving head loss estimates that are seemingly so out of line with the rest of the industry?
My Cameron's gives me 2.01' / 100' for 6000 gpm thru sch 40 new steel pipe.
Man, that would be one rough pipe to give 9.31'/100' headloss. I just use a friction factor correlation in my spreadsheets, and roughness would need to be more than 1/2" to give that sort of headloss.
You're reading the table wrong. The flow rates for the 14" pipe on the left are not the same as for the 16" on the right. The friction values for 13000 gpm for the 16" pipe line up with those for 6000 gpm in a 14" pipe.
There's a double line down the middle of the page dividing the two categories.
Would that be a double white line by any chance?
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO BP
"Being GREEN isn't easy." Kermit[frog]
Yes, and you shouldn't cross it, fines and loss of licence can apply.
You're all right, I was just reading the table wrong. I knew Cameron wouldn't be that far off. Thank you for all the help, that's one mistake that I won't ever make again.
Some of the best engineering I do is based on mistakes that I will never make again.
rmw
