This is the spreadsheet. Open the spreadsheet, open tools, macro, visual basic editor. highlight modules, click on file, import file, and locate the visual basic module I attached in the previous post. I usually save these in my personal.xls file so it can be used on any spreadsheet, if you don't, you have to import the basic module into every sheet. Close the visual basic screen. I made a button in the toolbar and attached the macro "ManningIn", you can also, just go to tools, macro, macros and run ManningIn from there.
Here's how it works. Put your cursor in the manning spreadsheet tab "manng" over any cell in the column labeled depth, you can erase one of the cells I filled in to see it work. After clicking on the cell, run the macro, it will fill the depth and velocity automatically. Note, the macro is set up for the way the cells are set up in this spreadsheet. If you have any other questions, let me know.
