Pipe and Supports Material Specification Selection
Gerald_SJ
1
Good Day!
I am new to a design and consultancy firm. Can someone help me. My question is, What standard to be look when I need to know the pipe & support material specifications for specific services. For example. I need to know the piping and support material to be used for waste water conveyance. thanks.
The answer to your question is affected by your location, the type of industry, common practice in your firm, and many other things. If you are new I don't think anyone will have a problem with you asking how they normally do that. Ask your coworkers.
One other resource is to check the engineering design procedures and guidelines under your Discipline of the Company on-line page. As a Design Consulting Firm, it should have established these specification & standard of multiple Disciplines for using in the Engineering work.
