Pillow block mounted on linear bearing???
Superslinky
Automotive
Sep 26, 2005
101
Anyone have any experience in this? My design is a lift using a lever so when the lever is rotated providing the lift the radius changes. I thought a pillow block mounted directly to a linear rail would do the job. Any thoughts?
Thanks,
Should work. Go for it! Don't forget to verify slewing moment and radial oscillatory coefficients though.
-handleman, CSWP (The new, easy test)
Bearings are typically used in pairs.
