I have two geotechnical reports (prepared by different geotechnical engineering companies) pertaining to two different sites, each with similar soil profiles. The soil profile at both sites consists of clay overlying a weak sandstone bedrock which has layers of shale/siltstone interbedded in the sandstone.
Both reports provide recommendations for driven pipe piles (the locations are remote and both owners have requested recommendations for the use of driven pipe piles) but their skin friction values are very different. Both geotechnical engineers recommend driving pipe piles into predrilled holes with hole diameters equal to 95% of the pipe OD. However, one geotechincal engineer provides allowable skin frition values of 100 kPa in the bedrock, whereas the other geotech engineer recommends an allowable skin friction value of 40 kPa.
I am curious as to how these values were arrived at. I have found literature on the skin friction (or unit rock socket side shear capacity) to use for drilled concrete piles in bedrock, but not pre-drilled and then driven piles. Is there any load test data for this type of installation? Is there any design literature?
Comments appreciated.
