Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
An sop has to be written, and a proper structural analysis. Job has to be stopped until your satisfied with the correct answers.After fabrication steel workers roll the pile cage which causes the longitudinal rebars to get twisted. ( Pic attached)
will this effect the pile load capacity?
Shirley you can't be seriousAn sop has to be written, and a proper structural analysis. Job has to be stopped until your satisfied with the correct answers.
No simple answer.
Can you explainShirley you can't be serious
Ya explain show your numbers, how does this effect structual integrity. Your statement is ridiculousCan you explain
Question Was for blockhead, this is not my specialty. How ever free body diagram should be drawn. What is the design intent, is acceptable to design drawings. It's above my pay scale..i read in a study that fabricating the main longitudinal bars in a spiral/helical shape actually increases the Load carrying capacity of the column ( ie , pile ).
Such long rebar cages are definitely outside my area of experience, but some of the photos suggest to me someone should be concerned. Some cages seem to be too eccentric. Looks like a problem which needs a remedy.BA, I have bad news for you about construction tolerances…
