oldestguy
Geotechnical
- Jun 6, 2006
- 5,183
I'd like to hear opinions on this.
For years I've been estimating pile lengths by combining side friction and end bearing estimates, generally mostly for highway bridges. Usually I can hit final driven lengths within 5 feet of this estimate.
For piles on rock, generally I've taken the driven pile capacity as being governed by stresses during driving, and for length estimates assuming near 100 percent as end bearing, depending on rock type and soundness.
Now comes a railroad bridge designer that wants pile "bearing capacity" of a rather sound sandstone. I'd have given it a near 100 percent of load as the end bearing part. My experience with piles of 60 tons or less is that the field capacity is determiend by driving resistance or possibly a load test. I've given little thought to rock bearing "safety factor" or "end bearing capacity" as a number based upon "strength of the rock". Never had any settle later.
One of my references, "Pile Foundations" by Chellis would indicate there is a significant safety factor for almost any rock that is confined. That is why I don't get involved there.
Apparently the designer would like to use some formula, such as those suitable for soil. He isn't satisfied with something like "100 percent of design load". I suppose I could pull a number out of the air, like 100 tons per sq. ft. I'd want to be high enough so that his driving stresses would then govern.
What would you do?
What would you do?
