Out of curiosity - is there a standard format for pile driving surveys that is widely accepted in the industry? I've always required them, but have thus far not specified anything too detailed for the requirement. As a result, I've had everything from a sketch on what was little more than a used napkin to a nicely formatted DWG showing precise placement overlaid on the original drawing PDF with all tolerance violations annotated.
I'm considering writing such a spec to push the received documents toward the latter's end of the spectrum, but don't want to spend the time if such a standard exists out there in the ether.
Any ideas? Thanks.
Any ideas? Thanks.
