Hopefully posted within the correct forum to get the most. Iews, replies and experiences.
I am currently working on a new build on-shore gas processing facility. As part of the build, a large pipeline transporting mainly clean gas with some liquids (c5+)is being attached. It is expected that the pipeline will require to be pigged once a week to ensure liquid slugs are brought through.
Obviously as part of the design we have an appropriate pig receiverbeing installed and this is wheremy question is.
The pig receiver in question is an appropriate rated pressure vessel with a bandlock door seal. Due to the make upof the new facility it is actually located in the middle of the plant (slightly different from other facilites).
In your experiences, in what state would people normally leave the pig receiver? Isolated, Depressurised and inertered or isolated and left at pressure with hydrocarbons?
The current design (as I believe with most pig receivers) does not have a relief valve but is rated for the maximum pipeline pressure. However, a design has been made to fireproof the vessel.
Really appreciate any comments.
