S
Semus
Guest
Hey fellas,
I'm relatively new to SolidWorks as my company has just switched over from another program.
I started a new sketch on the front plane when I meant to start the sketch on the top plane. This is a sheet metal part and I wanted to make sure it's orientated correctly.
How can I get my sketch to show up on the top plane and not the front plane? Is there a way to move the entire sketch?
Or, is there a way to switch out the front view for the top view. I believe Inventor has a way to switch your view to whatever you prefer (by that I mean change the top view to the bottom view, for example). For example, let's say I started a sketch on the top view and I now want that top view to be the side view instead. Is there a way to switch it out?
If not, what's the best way to move a sketch so that it's orientated on the top plane instead of the front plane and keep the origin?
