Hiya-
You will not get 1 micron out of "Photolithography" in the
standard sense. The old stuff (glass masks) were ALMOST
that good.
Temperature control, LOTS and LOTS of trial and error.
Film, no way. Edge effects of the "grain" will blow your
requirements out of the weeds. I've used some "good"
kodalith, mighty fine lenses and some really good photo
enlargers and I still get grain limits.
There are tricks that you can play with multiline, out of
phase limiting marks/lines that will allow better resolution
that the raw marks.
Also, reference against a resolution error table based
upon calibration with a laser interferometer can be used.
Still, there is a reason that this sort of accuracy costs
so much.
As an aside, you might look into a Fabry-Perot Interferometer
as an alternative.
That's pretty good at a relative displacement thing around
a couple of hundred nanometers.
Hummmm, I wonder what the track to track spacing of a
typical CD or DVD is? Look at the galvenometer reading
of a DVD player solid state laser assembly......
Hope this helps.
Cheers,
Rich S.
