I desperately require some circuitry advice before I go mad!
I have built some interface circuits for silicon photodiodes (quadrant detector) which seem to work on a knife edge.
I have tried different op amps with low input bias currents, all have not seemed immuned from problems. In the latest circuit I'm trying to debug I'm using the AD711 op amp.
The first stage is made up of the photodiode across the inputs to the opamp with a 1M feedback resistor to convert nA to mV. This seems to work fine the voltage goes up and down with light intensity. However, I need to amplify in a second stage to get the mVs signal up to Vs. I do this with a bog standard inverting amplifier. However, the second stage does not seem to deliver the gain. If I lower the gain to 2 we start seeing the expected voltage. I have similar non-ideal behaviour when I tried a non-inverting amplifier. Note that when I replace the first stage with a small voltage source the second gain stage works fine.
Does anyone know what op amp limitations are restricting the gain functionality in the second stage?
