I am trying to write a new assembly torque specification for our product, but I'm running into a quandry that Google is not helping me solve. This is not a high-stress structure, but it is a primarily sheet-metal product that needs to do a sufficient job of holding itself together through shipping and daily use. We've had problems with fasteners loosening and falling out due to insufficient installation torques, so we're writing our assembly facility a spec.
The problem is that we are currently (I'm trying to change this) specifying a lot of phillips head button screws. I can find plenty of specs for torquing cap screws and hex screws of these sizes, but I think that a cheap, standard phillips head screw must change the failure mode. It seems to me that the phillips contour will strip out long before a standard hex head preload torque is reached.
a) Is that a correct presumption?
b) If it is, then does anyone have a guide or an idea of what the reduction is to transition from a standard torque spec to a phillips head torque spec?
These are all steel-on-steel fastener interfaces.
Thank you,
~Vay
Thank you,
~Vay
