pH meter for Oily Water Service 1
khan101
Petroleum
I am looking for a pH meter for oily water service. This stream has 1-4% bitumen and has 10-15% sand. The line size is 16 inch and line pressure is 70 psig. Temperature is around 60C. I was thinking about installing the probe into a slip stream with an isolatable system. Any suggestion?
The problem encountered is not temperature nor pressure or sand but bitumen and oily phase.It appears as organic emulsion of about colloid size. A colloid particle (or emulsion droplet) is surrounded by its specific ionic layers that change the distribution of H+ ions arround it. Consequently the fraction of the pH electrode surface that is covered by oily colloid will not sense activity of H+ ions of the bulk solution that pH value coresponds to but will measure the activity of H+ arround the colloid adjacent to the electrode surface and the reading of the instrument will consist of a fraction of real H+ activity and a fraction of H+ activity of the ionic athmosphere of colloid particles.
Many times a good correlation exists among pH and conductivity.This property is much more easy to measure and with contactless electrodes a few percent of emulsion will not really spoil the measurement.The sand that is in a case of pH measurement beneficial because it cleans the surface of the electrode permanently could be removed by a small inline separator.
m777182
