pH control / titration curve
trotski
Chemical
Oct 23, 2007
1
I've thinkin' a lot about a smart regulation of an actuated valve related to the titration curve os an acid/base equilibrium but without success.
My procees requirementes are to remain the pH in an SP value and vary the ammount of acid... Can anybody give me a suggestion?
Well you have your work cut out for you... PH is possibly THE hardest thing to control. I have been thrashed by it myself.
Check Omega's offerings and their technical dissertation on the subject. Note that a controller that would cost $150 to do all kinds of temperatures costs $800 to do pH.
pH Control: A Magical Mystery Tour
Keith Cress
Flamin Systems, Inc.-
Also, pH is on a logarithmic scale, while most controllers are not. That would also add to the complexity?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
ISA published a book, aptly entitled "pH control", by Greg McMillan, in the mid 1980's. Used copies are available from half.com and used book vendors.
ISBN I have for the book is 0876647255
Dan
