Hi Kedar,
you may look for this literature:
A. Heintz, W. Stephan: A generalized solution-diffusion model of the pervaporation process through composite membranes
Part I. Prediction of mixture solubilities in the dense active layer using the UNIQUAC model, Journal of Membrane Science 89(1994)143-151.
Part II. Concentration polarization, coupled diffusion and the influence of the porous support layer, Journal of Membrane Science 89(1994)153-169.
Heintz and Stephan used PVA/PAN membranes for their water/alcohol separation experiments and simulation, resp.
Please note: Influence of liquid boundary layer and the membrane support, resp., can be essential and should allways be considered!
B.K. Srinivas, M.M. El-Halwagi: Optimal design of pervaporation systems for waste reduction, Computers chem Engng, 17(1993)957-970.
Connection of several PV stages for optimal network operation.
Best regards
Lorenz Kraetz
