Let’s start with the fundamental rules...
(i) A 90” angle applies where center lines and
lines depicting features are shown on a drawing at
right angles and no angle is specified. See para.
2.1.1.2.
Notice the word lines and not points?
Can you have a point at a right angle?
(j) A 90” basic angle applies where center lines
of features in a pattern or surfaces shown at right
angles on the drawing are located or defined by basic
dimensions and no angle is specified.
Notice the word "surfaces" and not "points"...
or how about ASME Y14.2
2.3 Visible lines
Visible lines consist of solid lines and shall be used for representing edges or contours.
Can you show me the mathematical standard were 2+2=4?
or how about the mathematical standard for definition for a square, rectangle, cylinder, diameter, radius, right triangle etc; geometric relationships in general...
How does one create a mechanical engineering drawing without having basic drafting 101.... you realize that "101" is a
colloquialism for fundamental drafting....
Actually did have an engineering college student in a CAD class that asked me what a radius was.
Problem is that many folks never had drafting 101...
and don’t forget logic and common sense... which aint too common anymore....
What would be the logic of that dimension being to the "corner points"? If one really needed to identify the dimension "points" they could be identified as points. This would be the exception not the norm.
Maybe this is a parallelogram or trapezoid in disguise and you just fooled me...
