Permissible Noise Exposures
CountOlaf
141
Safety guys:
I know OSHA has that section/chart where "hours per day" exposure correlates to "sound level in dB" beginning at 90 and going up to 115 with a corresponding 8 hrs declining to 0.25 hrs of permissible exposure.
My question is:
I seem to recall a magic number like 85 db that you don't want to exceed with noise-generating equipment. This could have been a specific company's policy (e.g., Chrysler) and perhaps by not exceeding this number and knowing that a normal shift is 8 hrs, you wouldn't have a "hearing protection required" issue. Is this true or is it some other number? 80 or 90?
In the US we have to monitor employee hearing when exposed to sound greater than 85 db. Word search the regulations for 85 db.
John
Excerpts from § 1910.95 Occupational noise exposure
(c) Hearing conservation program. (1) The employer shall administer a continuing, effective hearing conservation program, as described in paragraphs (c) through (o) of this section, whenever employee noise exposures equal or exceed an 8-hour time-weighted average sound level (TWA) of 85 decibels measured on the A scale (slow response) or, equivalently, a dose of fifty percent.
For purposes of the hearing conservation program, employee noise exposures shall be computed in accordance with appendix A and Table G–16a, and without regard to any attenuation provided by the use of personal protective equipment.
(2) For purposes of paragraphs (c) through (n) of this section, an 8-hour time-weighted average of 85 decibels or a dose of fifty percent shall also be referred to as the action level.
(d) Monitoring. (1) When information indicates that any employee’s exposure may equal or exceed an 8-hour time weighted average of 85 decibels, the employer shall develop and implement a monitoring program.
John
A quotation from OSHA General Industry Standards, section 1910.95(c)(1)
The employer shall administer a continuing, effective hearing conservation program, as described in paragraphs (c) through (o) of this section, whenever employee noise exposures equal or exceed an 8-hour time-weighted average sound level (TWA) of 85 decibels measured on the A scale (slow response) or, equivalently, a dose of fifty percent. For purposes of the hearing conservation program, employee noise exposures shall be computed in accordance with appendix A and Table G-16a, and without regard to any attenuation provided by the use of personal protective equipment.
Thank you all. I guess 85 is the magic number.
