MadEngineer13
I am working on a project wich will require two pieces of aluminum to be permanantly bonded with adhesive. The material will either be 6061 or 7075. Curently we are planning on using 1/32 inch roll pins for allignment and strenght once the adhesive has cured. This part will be subjected to moderate climate/environmental changes, and moderate shocks as well. The shock axis will be parallel to the glue line. I also need a long set up time, probably one or two hours, and the glue should be thin enough to penetrate small features. Does anyone have any suggestions or experience with this sort of problem? Thanks, MadEngineer13
