Jike-
I hear you. The issues you discuss are not just with wood buildings, although I think the inaccurate perceptions you describe are usually far worse for wood projects than those made from other types of materials.
We have a fair number of existing low-rise one- and two-story commercial wood structures in this area, and more are going up all the time. Wood is getting to be a “hot” material right now because the cost of steel and concrete are so unstable and high.
I would rather design a wood building than any other type, because timber can be a renewable resource, but there are so many obstacles to getting a correctly designed and built structure in wood, you need to think about even taking the work.
In my area, there are designers who issue drawings that don't comply with the code, but they seem to get away with it regularly. Even though, for certain building uses (for example a medical office building) both a local and state review of the plans is required before a permit is issued. If done in wood, these types of buildings can be large enough that they can not be designed prescriptively and must adhere to IBC 2000.
We have found that despite review of building plans from two sets of eyes from two jurisdictions, plan reviewers frequently miss major structural items in wood buildings, especially regarding lateral force resisting issues. This year, so far I have seen wood framed office building plan sets prepared by three different professionals with no discernible lateral force resisting system. None. And these buildings got permits.
No shear walls (or place for any), no hold downs, no way the diaphragm works because the aspect ratio is way off, missing load paths between adjacent diaphragms or between diaphragms and shear walls, no chords for the diaphragm, no connections for holding down rafters with uplift, the list goes on and on. Calculations are not required to notice these things, they are basic. But they get missed by the reviewers.
I get to see this stuff because my office sometimes does fit-outs for building shells that have been designed and erected only one or two years earlier. We see all kinds of crap, from both Engineers who should know better, and from Architects who clearly have no clue what they are doing. As you have pointed out, there are professionals out there who are willing to seal the most rudimentary, schematic drawings you can imagine and call it a finished structural design. And they get permits. I have theories on why this happens, but that’s for another post. In the end, it is impossible to compete against such practices.
Our direct experiences when working on new wood building designs have generally not been favorable either. I have had more than one Architect complain about “over design” when I request the necessary shear walls and hold downs. (“But this is not much bigger than a house” I have heard). Their eyes get cloudy when I start talking about drag struts or seismic forces, overturning moments, etc. At our office we are very willing to cheerfully explain the why’s of our designs, (after all it’s very interesting to us) but in the end what we are really doing is trying to teach something of our profession. However, our clients are not really interested. Not really. They want their drawings, and please don’t be too conservative (i.e., don’t follow the code too closely).
Connection design for even relatively simple wood buildings can also easily consume many more hours than expected. Despite the availability of prefabricated connectors from Simpson and USP, situations frequently can arise that require something custom. I find this to be especially true when connecting structural ridges and valley girders together in a roof with varying hips and gables.
During the construction of a wood building, builders will tell the Owners and also complain to the Architects that the Engineers have over-designed the structure. The builder has no responsibility for the fitness of the structural design, and may not have a clue, but he usually has the Owner’s ear. I sometimes think that Contractors only measure square feet when they bid on a set of plans, but then they get really cranky when the Engineer requires them to actually follow the details during construction. When the Builder gets cranky, the Owner gets cranky. Then the Architect hears about it and gets cranky. Then we hear about it. It can get to be a regular cranky-fest.
Funny things can happen. On one very substantial building, when we continued insisting that the second floor diaphragm needed to extend all the way to the exterior wall plates as shown on the drawings, we were thrown off the job. On another, when the Contractor asked about why there had to be eave blocking, the Architect told him to not to install it, and didn’t bother to tell us about the question.
Quite often we have limited access to the Owner and it’s difficult to reverse the impressions he has due to what the Contractor has whispered to him. This dynamic gets really bad when the Owner is also the builder, which I see more often these days. It is also magnified in wood-framed construction, because many individuals who have a background in residential work think that is sufficient to allow them to judge the design.
Some suggestions, Jike: Don’t normally pursue commercial wood design work. If you have to work on a new or existing wood building do it only as a favor to a valued client. Structure your fee conservatively. Hew as closely to the code as you can and try to explain why. Insist on periodic field review as part of your Scope with wood. If the existing design of a wood building you're modifying obviously doesn’t work, say so, let the chips fall as they may, and let the other designer clean up his own mess.
