Jan 29, 2005 Thread starter #2 A atmurthi Guest Hai Rams 1 draw a circle 2 draw 5 entities coincided with the circle and with each other 3 the angle between two entities is 108 degrees b4 that you give equal constraints and here is your pentagon bye
Dec 30, 2008 Thread starter #3 T Triple-Ess Guest draw ur desired circle, draw a line from center to outer circle. Pattern in 5 now draw lines from pt to pt concident with circle. enjoy
